Water in expansion vessel
2 Dec 2003
On the advice I received from this forum about my heating problems. The first step was to check the pressure in my expansion vessel,and increase by using a footpump if found to be low.On removing the plastic cap and depressing the valve when attaching the footpump to the expansion vessel valve,there was a spray of water under pressure issuing from the valve. Would I be correct in saying this should not have happened and my expansion vessel is faulty. ANY HELP ON THIS MATTER WOULD BE APPRECIATED.
No option I'm afraid, replace it. (unless it was only a very, very small amount of water that could be condensation)
I have looked again and it appears to be a large amount of water, so no other option but to replace my expansion vavle. What would I expect to pay for an engineer to supply and fit, or is this something I could to myself.
You could replace it yourself on some boilers, the price will vary from £25-£70 for the vessel depending on size or shape. If you have the space you could fit an external one by adding a Tee connection on the flow pipe. You need one at least 10% of the total system volume. It can never be too big.
For fitting add £40, maybe more I can't say really....
Thanks oilman, replaced expansion vessel 3 days ago and combi pressure now stable.Engineer charged £84.
Was it an internal or external vessel, and what size? What type of boiler?
The expansion vessel was internal, about rugby ball size and was part of a Worcester Bosch 350 combi.
