Extending a ring main
24 Jan 2007
West Midlands
Hi everyone
I would like to add another socket in my dining room. An existing socket already exists in there that is part of the ring.
I would like to extend the ring so accommodate the new socket. However, as the room is completely decorated, I do not really have the option of knocking out a large area to accommodate a junction box.
My question is; Can I crimp the existing power cable to a new length of cable that I can then connect to the new socket and loop back to the existing one?
Thanks in advance for your help.
Regards
Dave
It's not ideal, but you can bury a crimp (as long as it's made by an appropriate compression tool, i.e. one with a ratchet mechanism, not a cheap one), however, the cabling must still be in safe zones (horizontally and vertically from an accessory, and a few others). Can you get under the floor, as if so you could extend it with crimps there?
The floor is concrete so no luck there..
I am intending to run the cable behind the skirting board that runs around the room.
Thanks for your help.
Dave
Unless you have accessories on your skirting board (which I'm fairly sure is against the current regs so you shouldn't), then that isn't a safe zone, so unless you can bury your cables at more than 50mm (unlikely as that's normally too far in to a wall), or you use earthed metal conduit or something such as SWA, you can't run your cables there...
Rebuke is right. The reason is that people fitting skirting tend to use 3 inch clasp nails - and thats where your cables will be!!
