extending conrete post
16 Apr 2006
Middlesex
I wish to put 1 foot trellis panels on each of seven 5 foot fence panels. The fence panels are supported by concrete posts. Ideas would be appreciated for designing "something" to fix to and on top of the posts to support each trellis. Thanks!
if you increase the height of the posts it will at best look a bit of a bodge. if the panels are in good condition, then screw some batten to each panel the whole height at each end and screw the trellis to that. Even batter if you can do it to the back of the fence!
To do the job neatly, so that the trellis panels are secure, will be very difficult in my opinion.
sandwell Point taken. As the job is more a necessity than choice I must do the best I can. Thanks for replying though.
Thermo Thanks,I didn't think of that! The battens will have to be in slightly from the ends of the panels as they are of cause within the grooves of the concrete posts but this is no problem. The only firm connection for the battens will therefore be the tops and bottoms of the panels unless I put a batten of each side of the fence and connect each batten to the other. This will provide extra support and strength. After the trellis is erected it will simply leave me with a small gap between each trellis of about 2 inches (the width of the concrete posts less grooves) to cover with a fillet. Thanks again.
