Extending Maplin Multi Voltage Regulated AC/DC Adaptor
30 Apr 2012
London
Hi everyone,
I need to extend the leads of 3 Multi Voltage Regulated AC/DC Adaptor bought at Maplin. They will have to be extended of about 80cm for an artwork I am working on.
Specs are as follows:
Regulated
Input Voltage Ac 100 - 240V
Output voltage - Output current
9V - 0.5A
Current variable.
I am a bit of a newbie, I was thinking about buying some wire and extend the lead, should this be a specific wire?
Also, should I keep the tip or can I just plug the wires in a breadboard?
Many thanks in advance for all your help.
Best wishes
Elso
As long as it matches the gauge and rating of the existing I'm sure it will be OK. Solder the leads together with some heat-shrink over the top (don't forget to slip the heatshrink on first before soldering). Also stagger the connections so you don't end up with one big bulge in the cable.
Connect onto the breadboard with some solder pins to avoid damaging the board, although I have just plugged in tinned wires in the past. Keep the tip if you think you'll need it again.
And use a multimeter set to a DC voltage range to check you have positive and negative the right way round. Otherwise your breadboard will die.
