You're right - cheers. Just had another look and it's the boiler condensation pipe.A sink overflow would normally connect into the bottom of the sink waste with a piece of corrugated pipe and not usually a separate pipe like that, are you sure that's a sink overflow and not say a condensate pipe from the boiler?
If that is just an open ended 45deg coupler then a piece of 21.5mm overflow pipe would be glued into that.
View attachment 322638![]()
FloPlast Overflow Pipe White 21.5mm x 3m - Screwfix
Order online at Screwfix.com. A 21.5mm solvent weld overflow system in white PVC-U. No expansion gap required on the solvent weld overflow system. Apply solvent cement evenly to both surfaces of joint, insert pipe fully in the socket depth and remove surplus cement with a cloth. Allow five...www.screwfix.com
I would think this should be open ended if so?You're right - cheers. Just had another look and it's the boiler condensation pipe.
Can I just use some tube like the one from my washing machine out pipe and just use a screw clip to attach it to some hose that I stick down that pipe?
Goes into the waste pipe of the sink.Where is it (larger pipe) going to?
Is this a trapped entry to the drains or just a pipe sticking out the wall?
Seems odd to have it open ended.
I mean attach the hose to the top pipe and have it open ended into the bigger pipe below. Hopefully that's ok as that's what our builders did! Just without the hose.I would think this should be open ended if so?
You wouldn't want to create a syphon block on this line?
Curious.Goes into the waste pipe of the sink.
