Extension floor insulation thickness
21 Jul 2022
Hi folks,
We are in the process of getting a rear extension built with the following sandwich layer:
Finished floor
screed with wet UFH heating
PIR insulation boards
Concrete
DPC layer
Hardcore
Is there anything in the regulation which dictates the thickness of the PIR insulation boards? I have had a look online and can't seem to find anything and our building control inspector has gone AWOL... :S
Cheers!
I googled ......building regs. insulation in floors ....got results + pictures (y)
The manufacturer of the UFH will also specify a requirement.
Do you have proper plans drawn up or are you winging it?
We do have some proper plans drawn up, but our building control inspector has asked us to do additional things that weren't documented on the initial plans as and when he comes to inspect, so I am just trying to arm myself with some information so we can counter him if it comes to it
If you had plans sent in for approval, getting that approval would require the floor insulation to be specified.
What type and thickness is specified on the plans?
If the plans have been approved the site inspector can't alter the approved insulation specified on the approved plan.
