extention footings
Is this extension covered by Building Reg's/Planning Permission?
If so what does your BCO/Architect expect?
Are you asking about the footings or the slab?
What's the situation so far?
what has B.C said is it not on the plans for the groundworks tend too use rebar not much cage work ask building regs
If your foundation plans show a reinforced cage, then yes you need that before concreting..
The OPs post makes no sense at all
If this side extension is at the zoo, then yes you need a cage
If this in on a house, then no, just build it out of blocks and brick like normal
