- Joined
- 16 Dec 2019
- Messages
- 6
- Reaction score
- 0
- Country
Hi all - in the process of purchasing a house built in the 1980's - the top half of which is covered with clay (?) tiles. My question is what is under it?! Looking at the window recesses it would seem there is not much more than 6 inches of thickness between the inside wall and where the tile batten would sit. Another clue is the bottom 10 rows or so of tiles fan out wider so as to appear to be about 4 inches further away to presumably meet the thicker cavity wall of the ground floor ?
So could i assume then, that the ground floor is probably a cavity and the top is single block covered with wall tiles ? If so, any potential problems with that ?
Ironically, I am also considering a more modern house built about 15 years ago which also has external tiles top half - however these appear to be uniform all the way up and the window recesses are wider so presumably brick & block all the way but if so WHY tile too? Surely adds considerably to build cost
How can I be sure whats underneath before survey ?
Thanks in advance
Snolly
Thanks in advance
Snolly
