Depends on where it is being run.
Please describe the cable route from start to finish, then we can advise you.
The first line of your response should say something like:
The cable would start at the house end, fed from (where????????)
and then
It would then be clipped down the wall and will be buried in the garden for 10 metres
It would then be clipped up a tree and then attached to a length of steel catenary wire to the garage. This is situated 150 metres away on the other side of the M6 motorway....
You get the idea..
IMO that would contravene Wiring Regulation 134.1.1Would flexi pvc conduit work for containment of T&E during external run?
And it will look cr*p.
I think you need to get out more.
Abusive? Deliberately designed to inflame or anger you and generate an emotional response?
Don't be ridiculous.
You asked a question about using flexible conduit for a cable run clipped to an outside wall.
I said that I thought that would contravene the Wiring Regulations.
Please explain how that is either abusive or trolling.
I also said that it will look cr*p. Which is absolutely true.
