External lagging
7 Sep 2009
Hampshire
During the cold snap earlier this year the external waste water pipe from my combi boiler froze causing the boiler to stop working. The solution was fairly simple. I used a hair dryer to gently thaw it out and then covered it with an adapted piece of hot water tank lagging. This worked fine and I had no further problems during the winter. However the solution is a bit unsightly and I was wondering if anyone could recommend another type of lagging intended for extrior use (preferably white).
armaflex insulation which is black unfortunately fo you,or do what should have been done and increase the pipe size from overflow to 32mm white pipe.
