We have a very cold 1906 semi with solid brick walls. I am looking at insulation solutions, particularly for the walls. Not DIY, will get in specialist contractor.
There is a long (12m long by 7m high) flank wall along the side alley in permanent shade. This is in need of repointing and the cost (circa £2,000) is making me consider insulating it externally instead.
Some questions:
1. Roughly how much will this cost?
2. If I insulate, can I avoid the repointing?
3. How thick / thin is a typical installation?
4. The main soil stack is against this wall, with a gap of 3cm. There are also waste water pipes running externally diagonally from the bathroom and kitchen to a couple of drains. Can the insulation system cope with this without needing to shift the stack and pipes?
Any recommendations for systems and contractors gratefully received.
Edit: How about this?
http://www.millfold.co.uk/external_wall.php
Some questions:
