extra radiator problem
28 Mar 2007
Nottinghamshire
Ive just fitted an extra radiator, i have taken the feed and return from existing rad pipes in the loft, the problem is that the radiator hardly gets warm, i have bled it and the system etc.
What type of system is it ? do you have a feed and expansion tank in the loft?
Have you tried increasing your pump speed?
Pete
Pete
Its a sealed system i.e with a combi boiler, i cant understand it because the other two radiators get as hot as they always did, the other is stone cold. I think I know how to adjust the pump speed, is it the large grooved disc on the end?
Try turning off all other rads and see if this will push water to it. May be an air lock in the pipework in the loft :wink:
Yes, sorry i forgot to say, if i turn the others off then it gets hot, it appears to be bled OK, however I can hear air in the pipes (only when the other rads are off though), i have used speedifit pipe by the way...
Have you got any air vents in the loft pipe work. You should have at least 2. If so have you bled via them?
Try taking rad off and put bucket over each rad valve in turn and opening valve to let water/air out etc.
Most combis will have the pump set to maximum anyway.
No it won't be the silver screw in the middle front. This is for bleeding the pump.
Sounds like air in the pipe still.
You will also need to balance the rads to give a little more bias to the new one
A couple of air bleeds would certainly help
Try running with only that rad on (from that circuit) for a while it may push the air out after a bit
