EXTRA SOCKETS NEEDED!!!!!!!!!!!!
8 Nov 2008
Essex
Hello All,
Can you please help!!!!!!
In my conservatory there is a 13amp FCU and 1 dbl socket which is spured from the ring main in the hse, this was fitted by a pro which also fitted a 40amp RCD to my fuse box!
As i need more power in the conservatory which will be pluged in by 13amp FCU (with flex outlet)
HOW CAN I FEED THE EXTRA FCB?
CAN I TAKE A FEED OFF THE ORIGINAL FCU OR SOCKET?
you don't need to fit another FCU just take a feed from the 1st socket to the next.
THE POWER IS NEED FOR SENSORY ROOM EQUIPMENT IE BUBBLE LAMP, FIBRE OPTICS AND MIRROR BALL ECT
SO I NEED AN EXTRA 8 POWER POINTS - BUT ONLY 1 OR 2 WILL BE ON AT ANY 1 TIME.
THE COMPANY SURPLYING THIS EQUIPMENT recommend THE ITEMS TO BE HARD WIRED INSTEAD OF PLUGED IN!!!!!
SO COULD I JUST TAKE A FCU OFF A FCU AND SO ON!!!!!!!!!!!!!!!!!!
please stop shouting (typing in CAPITALS)
yes you can feed a bunch of FCUs from the first one, provided the 2nd and there after are fed from the LOAD side of the first FCU.
I also do not agree with the hard wired aspect.
unless the room is for small children i would suggest plug them in. if a child trips the plug may come out, if its hard wired it cant
