Extraction fan vent cover
11 Apr 2018
Whom do you hire to put a cover onto an extraction fan vent on the outside of a building?
If you can find someone with a long enough ladder who is willing/daft enough to do it then fit a cowling type cover if it doesn't already have one. You might also try getting a back draught shutter fitted which could be done internally. Any handy man should manage it.
I fitted a fan in third floor bathroom , used a length of string thru the hole to pull up outer grill and fixed with silicon thru the hole and cable ties to hold in position.
OP,
Use the DIY NOT search facility for: "Fitting an extractor 6 floors up" to get an idea of an all interior installation. No outside work needed. Then visit, say, Xpelair for more modern info.
