Extractor fan (bathroom ceiling) broken?
28 Dec 2006
Edinburgh
Hello. 2 questions:
1. Took cover off fan to remove soft obstruction from fan blades .. bits of loose wadding of some sort ( - a bit like old asbestos?? - tho this is a new house just 2yrd old). Should there be a grille or something in the flue to stop wee birds & beasties & traffic noise from getting in? ( - I can see daylight at end of shaft, which has a cap mostly covering it).
2. Tried to adjust fan overrun using 'dial screw' on PCB (turned it fully both ways) then it refused to work when I put it back together again. Have checked all wiring - seems sound. When I turn on light I can see the fan blades turn over *very* slowly, but the motor isn't properly kicking in (I can hear a faint humming noise from motor). I've tried turning dial to several positions - but no joy. Any suggestions what's happened/how to cure? Is it duff?
That isnt asbestos, its years and years of soggy human cells being sucked into the fan.
There should be a non return flap at the end (or in) the pipe to stop the winter gales blowing into your bathroom
Thanks TTC. The material is mostly fibrous and has hard bits in it (plaster?) - I'm wondering if its perhaps building debris (roof insulation?) that's recently worked loose?
No sign of a grille or mesh in flue - only a 'mushroom cap' over the end of pipe. What should I use ideally?
