hi ,my brother has brought a extractor fan which was a wall mounted fan with a pull cord switch . after a few months he went to fit it but at that point he realise he had brought the wrong one . he wanted a ceiling mounted fan instead.
i have taken apart the fan a cut off the pull cord switch and put in a terminal block so there is no more pull cord. i have taken the supply off the ring main then to a 3 pole isolator the the power from there to the fan.
ok the problem is .
he wants the fan to turn on with the pull cord light switch in the bath. how is this done?
the fan only has two connections live and neutral.
would it be easier to take the supply from the lighting circuit ? how would it be wired
thanks
ok the problem is .
thanks
