Whats the best extractor fans to buy for kitchen and bathroom also maybe lounge? Got damp walls and lounge has wet mark going down side of the underlay all the way down.
You sound like you got problems, riseing damp will only rise about 3' above ground level, if you have an external wall that can cause damp higher up, in modern houses moisture will build up if you dont open the windows, Victorian sash windows didn't have this problem, without more info i assume your not useing a bottle gas heater, i would advise opening top lites on your windows and getting a through draft.
River burst its banks!!
What? In July???
Perfectly possible!
Could also be melting polar ice caps.
What? In July???
Perfectly possible!
the op is in Cumbria.......of course its possible!....
Rising damp is no myth, what sort of floor have you got, wood or screed??
