    Dismiss Notice
Factory reset Honeywell Galaxy G2-20 ADT alarm
Discussion in 'Alarms, CCTV & Telephones' started by fazzy, 18 Jun 2015.
  1. fazzy
    fazzy
    18 Jun 2015
    3
    Thanks Received:
    Country:
    Hi
    Have just moved into a house with a Honeywell Galaxy G2-20 ADT alarm. I do not have any user or manager code. I would like to reset the system back to default so I can use the alarm. Can anyone tell me how do this. i understand this may be sensitive information so please PM if it not correct to put on a public forum.
    THANKS
  2. Sponsored Links
  3. ultomoat
    ultomoat
    2 Jun 2012
    65
    Thanks Received:
    8
    Country:
    It sounds like you need to call a local alarm company and get them to come and quote for this. They can also service the alarm for you and talk you through how it is configured.
    Note that this is a professional quality system so information on resetting codes isn't shared with anyone outside of the trade for security reasons.
  4. fazzy
    fazzy
    18 Jun 2015
    3
    Thanks Received:
    Country:
    I have installed full alarm systems on my previous three houses so i am ok how to configure it once reset. I have looked on this forum and others and found conflicting information on how to do this. I just need to factory reset it then i know the engineer code and them I am away.
  5. Europlex
    Europlex
    20 Nov 2007
    2,963
    Thanks Received:
    268
    Country:
    As post two.
  6. secureiam
    secureiam
    20 Jun 2014
    5,115
    Thanks Received:
    636
    Lancashire
    Country:
    No alarm engineer should/ would post defaulting information on a public forum, it is not ethical.
  7. Sponsored Links
  8. fazzy
    fazzy
    18 Jun 2015
    3
    Thanks Received:
    Country:
    If anybody that knows would be PM me that would be very helpful .
  9. ibruceuk
    ibruceuk
    11 Jun 2005
    185
    Thanks Received:
    17
    Lancashire
    Country:
    I understand peoples reluctance but often find myself asking the question why...
    Most (if not all) defaulting procedures require extensive physical access to the end station. Surely with a properly installed and designed system this would be totally impossible without first breaching the system when armed and/or triggering tampers?
  10. Europlex
    Europlex
    20 Nov 2007
    2,963
    Thanks Received:
    268
    Country:
    Doing what you are asking is very much the same as asking for an Engineer Code, you wouldn't get that either, it's all about security.
    We have no idea who you are and why you want to do as you ask - anything can be written in a forum.
    ps This is a more professional type of control panel, unlike a lot of the ones that get mentioned here.
    That, I suggest is why you are not getting what you require.
  11. EightyTwo
    EightyTwo
    14 Feb 2012
    1,126
    Thanks Received:
    169
    Cambridgeshire
    Country:
    Like he/she said...
    You'll get an even shorter response if you call the manufacturer... (n)
    Try searching the forum for other posts on defaulting Galaxy panels. You might get some clues or the name of a contributor that you could PM. ;)
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
