Having applied a mist coat of 5:1 matt emulsion:water to newly plastered walls (done 8 months ago) I decided to test whether it had stuck prior to a light sand. Using sellotape there were some areas where the entire mist coat came off and others where it was firmly stuck. Is this a true failure to adhere to the plaster and if so is the best measure to re-mist with a diluter mix?
