Good Evening,
I have a Biasi Riva Compact HE, attached model details
Fault Lights indicates as per Manual - "Lack of burner ignition (no ignition signal from the full sequence ignition device)
Works okay and reaches optimal Ch temperature and at this point flames go out, but still operational, i.e no fault lights and when temps drops it reignites again as it should.
But between 30 - 60 mins of use, it fails to restart
At this point, it cycles for a few times to reignite, during which i can hear the fan and even see sparks present but no flame. then goes to lock out lamp and fault code as above.
Work done so far - Replaced Pump, Ch Thermistor, Overheat Stat and Flue temp NTC probe.
Thanks in advance
View media item 59026 View media item 59027
Thanks in advance
