I’m connecting a 40mm shower waste into a vertical soil stack using a boss strap. The boss inlet will be side-entry (horizontal) into the stack and i have a rubber adaptor for the 40mm pipe to enter the boss inlet bit.
The distance from the shower tray outlet to the boss strap connection is roughly 70–80cm at most. The shower tray instructions state the waste pipe needs a minimum fall of 3cm per metre for proper drainage.
My plan was:
1. drop down vertically from the tray waste
2. then use an elbow and run straight into the boss strap.
But if I do that, the horizontal section into the boss is basically level (little/no fall).
Given the 3cm/m requirement, what’s the correct way to achieve the fall when the boss connection itself is horizontal?
Thank you
My plan was:
Thank you
