false wall
  • Thread starter Thread starter hav it
  • Start date Start date
H
hav it
Im currently building a false stud wall in bathroom.the bathroom wall will have a shower fitted and tiled.what is the best meterial to use to fit to the stud wall.i.e moisture resistant ply or plaster board.?
just where the shower will be, or along the hole stud wall in the bathroom where the tiles will be.
how thick would it need to be, is it the same thickness as plasterboard.can you tile direct to plaster board?many thanks.
to be quite honest with you i have only ever used 12.5mm marmox, and you can get 12.5 mm PB, that would keep your walls the same.Yes you can tile directly onto PB (plasterboard)
