Fan and Light
31 Oct 2004
I want to install a fan and a separate low voltage light for the bathroom. I want both to come on when the light is switched via the pull-cord. Both items will be located in the attic. The fan requires ELN wires and the transformer just needs N and L. The bathroom light is on a loop with all the other upstairs lights.
Any suggestions gratefully received. Thanks.
take note of existing wiring and put a junction box there, where old light was, connect to mains side of transformer, and fan
When I made enquires about low voltage lights being run off a
transformer with a fan on the same circuit I was told by the shop that the
fan would be an inductive load on the transformer and could damage the transformers.Is this correct.
the fan is not connected to the transformer so the statment is irelevant
How ever, anything wth a coil is an inductive load, fans have a motor = inductive load, guess what a transformer has , a coil so it too is an inductive load.
The only "problem" is that of an electronic transformer. it may be suseptable to "spikes" (back emf) from other inductive loads, but as its only a small fan in this case i would not worry
