baxi solo 3 60pl open vented system(pumped).boiler heats up for about 5 minutes,radiators get warm then flame goes out.electronically sparks up again ,lights ok again then flame goes out again after 30seconds.
this cycle just keeps on going so i switch it off.(as it does not sound to healthy with it combusting so much)
it is only 2 years old.
i opened the box and a small fan dropped out.there was only 2 blades left of the fan on top of a small electric motor which i take it drives the flue fan.
does this small fan have any bearing to what is happening with my boiler.
does it affect the pressure switch beside which in turn is cutting of the gas.
bear with me,as you can obviously tell i am only guessing
thanks
doogie
thanks
doogie
