I moved into this current house about 3 years ago and had no problems with wiring etc.
the kitchen has a built in AEG oven/fan oven. About a month ago the fan oven was on and the dinner was cooking, when all of a sudden the main circuit breaker on the fuse box (as I still call it) tripped. After some investigations it became apparent it was the fan oven that was causing the problem.
The oven and grill all work fine still, but if you turn the switch to the fan oven setting, everything goes off and you have to reset the circuit breaker under the stairs.
is there anything obvious I should check before calling out a pro to come and take a look at it.
