Ive fixed the above problem but would like some advice...
Anyway yesterday boiler started making a very fast clicking sound.
On opening things up I discovered it was the very fast spinning fan wheel.
The wheel and its power supply/solenoid are fixed by 3 bolts each of which goes through a rubber plug before screwing into bottom of flume [please forgive any inaccurate vocabulary]. There is also 'W' shaped bracket with a rubber plug which pushes up against the fan unit. I noticed that by changing the position of the wheel ever so slightly the noise disappeared - there had obviously been some friction / rubbing somewhere inside. I have been assured by helpline that it is still safe and that if the fan couldn't operate the boiler would simply cut out. Three questions..
1. Is it designed to deliberately have some give/free play? eg the bolts are narrower than the inside of their plugs. I assume if the thing were fixed absolutely rigid the speed of the fan wheel would cause vibrations and damage elsewhere.
2. Why has it been designed with so little tollerance regarding free spinning versus friction. Its ok now (and this is the first problem in nearly 2 yrs) but is the thing going to gradually work itself out of position again.
3. Is this sort of thing a common problem?
