fascias soffit gutter
19 Apr 2009
Yorkshire
i am thinking of replacing my fascias soffits and gutters as well as fall pipes, with u-pvc soffits and fascias will i have to remove my old ones or can i fix the new on top of the old.??
in anticipation Paul
Depends on the condition of the old ones; if they are sound timber you can overboard but if there is any sign of rot, take them down or they will continue to rot away beneath the cover boards & the whole lot will warp, look awful & may even fall down.
Personally, I think over boarding is a bit of a bodge & would only ever replace with full 22mm UPVC fascia boards & decent soffits. Considerably more work but your unlikely to ever have to replace or paint it; an annual wash & scrub will keep it looking like new for many, many years.
Agrees with Richard C. Capping over is a bodge job. Iv had to replace quite a few overclad jobs done by other tradesman. Its best to fully remove. I use 10mm solid soffits (not hollow boards) and 18mm replacement fascia boards. I have used 22mm fascia boards in the past but have since found a good manufacturer that makes very dense quite tough 18mm boards that are load bearing tested.
Boards I use are made by Floplast. You can find product info here:
www.floplast.co.uk
Another well known brand is Swish. They have a budget range under the name of Summit which is a lot cheaper.
http://www.swishbp.co.uk/swish-89
