The last couple of weeks my bathroom sink hot tap has been stiffening up when opening it. It's got the to the point now where sticks when I'm only getting a dribble of water out, I can't turn the (capstan) head any further than that point.
So now just trying to have a look at it. There is an in-line shut off valve on the down pipe, I turned this 90 degrees from vertical to horizontal, on the understanding that this would cut off the water supply, which has seem to do.
I took of the head cap, took the screw out, but then I couldn't get the capstan head/cover off (not sure how).
I drowned it all in WD40, and with a bit more pressure and gentle persuasion the spindle now goes to fully open (though I can tell it's full of crud in the gubbins, as it's not opening too willingly).
So I thought that would do for now, short term, and will have to get a plumber out to fix it properly.
So then I turned the tap to fully off, then I turned the in-line shut off valve back to it's vertical position, but now no water is coming through when I turn (force!) the tap on.
Any ideas?
Thanks in advance.
Steve
Any ideas?
Thanks in advance.
Steve
