- Joined
- 23 Nov 2019
- Messages
- 5
- Reaction score
- 1
- Country
hi any body come accross this fault
Hot water works correctly , no central heating , diverted valve working , if thermostat is wired out and wire bridgd for switch , the central heating will work every time the boiler is powered down and back up , soon as the switch wire opens , the central heating switches off and won’t come back on until the boile that’s been powered down the turned back on with the switch wire in place
I’ve fitted a new pcb and same symptoms
Any help would be much appreciated
Cheers
Phil
Cheers
Phil
