Hi All,
I've been handed-down an old dehumidifier (about 5 years old or so), and that I can use it if I can fix it! I have never had a dehumidifier before, but I have researched how the things work in principle.
Here's the problem:
When I turn the unit on, I am greeted with a 'clicking' noise, and the unit not collecting any water whatsoever.
Now, I have taken the unit to bits, and have found the following:
The user-knob is one single control. It controls the humidity setting, and operates a microswitch at the bottom-end to power on the machine. I have taken the switch unit out as shown below:
The power wires (one brown, and one purple) lead down to the compressor. The black wire leads to a small circuit board on the user panel which operates the on/off lights I assume.
The 'clicking' seems to be coming from inside the plastic box next to the compressor (is this the motor in here?!).
The plastic 'box' to the left of the compressor
Overview of dehumidifer
I know that:
The fan works fine, and the microswitch which recognizes the fill-tank operates successfully also.
I have a volt-meter, some basic electrical tools, and very basic physical electrical experience.
Does anybody feel they can help me out here in terms of any checks I can carry out or whatever? And also, should I maybe be looking towards the controls unit, or the motor/compressor components?
The dehumidifier model is a BCM ltd Dehumidifier BCM101 (DE22GY-GB)
Thanks for your time, and hope the photos are of use!
MT
Here's the problem:
I know that:
MT
