Frustrated as Kudos Straight Pivot door 900mm are aware of the shower seal problem.
The fault causes the water to leak through the bottom of the door.
After 3 calls to Kudos (the 3rd call was to chase as plumber had waited over an hour for engineer to call back) the engineer told my plumber that the fault was probably with the seal and a new one arrived in the post 2 days later. As you can imagine the plumber and his colleague not happy as they spent several hours trying to fix the problem.
Anyone familiar with Kudo Straight Pivot door and problems with door seal ?
Would be interested to hear if I am the only one !!!!
