I have installed a shower door from wicks, A sliver pivot door 760mm. Everything is level and square and have installed as per the instructions. It looks quite good but there is one problem. The shower leaks water out from where the door meets the piece of door frame which sits on the shower tray. There is a rubber piece on the bottom of the door to presumably take water away from doing this. The door iteslf comes already attached to the frame there is only one way of installing it either right hand opening or left hand opening. I think I have done everything right. Is anyone familiar with this kind of problem or suggests something I may have done wrong. Everywhere is sealed as tightlly as possible with sealant all roun. It is just this gap between the door frame and the door which is casuing me the problem.
If i were to take it back to wicks as faulty how do you think I would stand?
Any help is greatly appreciated!!!!
MOD
moved as posted in wrong forum
MOD
