I've had my house rewired, and I am having problems with the telephone socket, apparently after BT have reactivated it.
I'm not sure if it is BT or the electricians fault. I can't get hold of either at moment suprisingly!
Inside the master socket, there are 2 seperate cables, with White/Blue from each cable going in to A and Blue/White from each cable going in to B.
My understanding was that this is correct for the BT line, but the extention for the other socket should go through the 1-6 terminals? However, regardless of that fact, the master socket should still work if the BT line is wired correctly?
