FCU first rating
28 Nov 2026
Hi
Looking to hardwire 2 led drivers in parallel into an FCU on the ring main. One 24V driver (15W output) has an input current of 0.2A. Second 12V driver (36W output) doesn't say what it's input current is. Trying to figure out what fuse is needed in the FCU. Assuming 2A will be ok?
Joel
The fuse is to protect the output cable not the devices. The smallest cartridge fuse for an FCU is 3A as far as I am aware. So if you ae wanting to protect the drivers you may need to find in-line fuses and holders.
15W is a lot for an LED. 36W is enormous.
Is it to illuminate a large room?
What is the relevance of 24V and 12V?
You can get fuses to fit at other ratings, they are coloured black to show they are not standard. It might be wise to label the fuseholder.
It's not a single LED! They're LED strip lights. The 15W driver can supply about a 3m length, the 36W supplies 6m. They're for plinth and cupboard lighting.
I supplied the output voltage of the drivers to give an idea of the output current (0.6A and 3A) but I know that the fuse is rated for the input to the drivers, not their output
Yeh I've got 2A and 1A fuses that fit an FCU
