Feather edge clout
24 Oct 2012
Cornwall
What length of clout nail do I need for the feather edge boards? They are 22x150x1800mm.
Cheers.
At least twice the thickness of the board - with your 22mm I'd be looking at 50 or possibly 60mm long (if 50mm aren't available).
You only need one nail per rail in each board (that's 3 nails per board with 3 rails). With a 25mm overlap you nail 32mm from the thick edge so the nail only goes through one board but holds the thin edge of the previous board in place.
Brilliant, cheers mate.
Thank you for that. I had assumed for some reason that the nails went through two boards! I'll do it properly now, cheers.
A pleasure. By fixing as I described above it stops the boards from splitting with the movement in wood with the weather.
I was taught to hit the point of the nail to blunt it, with the head resting on somehiong hard,before hammering into thin wood to help stop splitting. Never questioned, just always done it that way
One thing. Is there a knack to nailing the series of boards in? If not nailing them together how does the one next to the one being nailed stay still? If you nail it without the other (non-nailed) board being there you might nailit too tight to get even the thin end in.
OK. You start at one end of the fence. With a spirit level determine which is the outside of the fence stating point (i.e. is the fence post upright or if an adjacent wall or fence is upright). If you are using gavel boards sit your first board on the gavel board, then ensure the first board is upright and put the first nail in around 32mm from the thick edge on the top rail, hammer in leaving around 5mm proud for now; repeat on the bottom rail, check for vertical - if all OK knock nails fully home and put a nail in the middle rail.
Now mark 25mm from the thin edge top and bottom. Place the 2nd board thick edge against the marks and nail 32mm in from the thick edge of the 2nd board. When the nails, top, bottom and middle are fully home the thin edge of the first board will now be held securely.
Repeat along the length of the fence.
With the above overlap using 125mm wide boards you need 10 boards per metre run, with 150mm boards you need 8 boards per metre run.
When you reach the end of fence boarding the penultimate board should be trimmed to finish 35 to 40mm short. you then cut the next board down to 50 to 55mm wide and fixed in the reverse direction with nails again 32mm from the thick edge.
One last question.
What is the best way to attach the capping to the feather boards? The upper rail is well below the top so that can't be used.
Cheers.
You need a counter rail ( baton around 60x20mm) to rear of top edge to fit capping rail too.
The closer the top and bottom rails are to end of feather edge the less they can warp or twist .
OP, My two pee's a bit late but as a general advice: if doing it by hand I've often found it worthwhile to pilot hole before nailing - it prevents splits of course.
