Hi I'm currently changing a pumped CH/gravity HW to fully pumped, the pump is going to be on what was the gravity flow from the left top tapping with two 2-port valves to do HW and CH. Only moving it to the other side due to space for valves.
The vent pipe is connected on what was the ch flow just before the top right tapping. The returns from CH and HW I was going to leave connected to the bottom left and right tapping's.
The feed from the expansion tank connects into a T at the cylinder return.
I know that both feed and vent ideally need to be before the pump, but would this work by leaving them connected as they are?
Thanks if anyone has any thoughts.
