I feel electricity in the water in the bathroom, we had work done 2 years ago and the earth ground wire was cut off. we never had any problems until recently. Does the problem come from that cut wire?
What ground wire, was cut. And where??
You should not be able to "feel" electricity anywhere in your house. If you can, you should get an electrician to check it out, it could be dangerous.
Can you explain what you mean by 'feel electricity'? What sort of sensations are you experiencing, and in what circumstances?I feel electricity in the water in the bathroom ...
As others have said, you need to get an electrician to check this out.
Kind Regards, John
Could have been an old earth rod for an old TT system. We need photos of your cutout and meter position please to see what earthing system you have. However I recommend getting an electrician in tommorow and not using the shower or bath in the mean time.
No.can humidity and moisture on the copper pipes and surrounding cause this?
Electrical work? What was the work done? It will be described on the installation certificate that you will have got when the work was completed.we had work done 2 years ago and the earth ground wire was cut off
For any electric shock. from a tingle to a FATAL shock there has to be two points of contact.its a tingling sensation, if we wear rubber sandals we do not feel anything
Do you have electric underfloor heating in the bathroom?
Had no answer to those easy questions. I hope the OP has had an electrician in and is not now having to carry out CPR on his family.Electrical work? What was the work done?
