Looking to remove 2 huge conifers. Probably about 60ft+ each.
I'm a confident climber and will be tying myself off to prevent fall risks.
While I'm happy to use a chainsaw at ground level, all high level work will be done with saws and brush hooks.
The trees were heavily pruned many years ago, and as such, don't feature a single central trunk which should make climbing and lowering of branches an easier job.
The battle plan is:
1) Climb up, remove all brunches smaller than 2 inches at the trunk(s) inc. foliage to clear a climbing path.
2) Starting at the bottom, remove any branches between 2inches and 4 inches to leave 6-12inches of branch as steps. Lowering them to the ground.
3) To remove the top most whippy part of the trunk(s), tie a rope above and below the intended cut point and cut duel V's. Then climb down and use another rope to pull and snap the branch. Then climb back up, attach another rope and lower it down.
4) Climb down, removing 2ft lengths at a time and lowering / dropping them to ground level.
Does anyone have any better ideas on how to address this? (without paying for someone else to do it)
Both trees are at the property boundry against a footpath and road that only see light use.
I'll be keeping the wood to season and burn. But what'll be the easiest & cheapest way to get rid of the foliage?
Cheers,
Fubar.
The battle plan is:
Cheers,
Fubar.
