- Joined
- 17 Oct 2017
- Messages
- 13
- Reaction score
- 0
- Country
I'm looking for advice please. I've done many fences over the years and never had a single problem. Until now.
For a standard fence panel of 5ft 10in high, you use a post of 7ft 10in, if no gravel board is used then the remaining 2ft of post goes in the ground. No problem there. But what about when you use a gravel board?
The industry standard for fence post depth varies between 1/3 of post or between 17in and 24in in the ground.
Posts are sold in 3m (9ft 10in), 2.4m (7ft 10in), 1.8m (5ft 10in).
Here is my issue with current fence.
the posts are 2.4m (7ft 10in)
The panels are 1.8m (5ft 10in)
The gravel board is 6in
So adding the panel and the gravel board together gives a total left to go in the ground of 1ft 6in. How can you possibly put minimum of 2ft in the ground? The only way I can see is if a 3m (9ft 10in) post was used. Meaning 3ft 4in in the ground. Am Iissimg something?
