Chaps, i am replacing the fence shown below. The post that is currently there is in some concrete at the bottom with a timber spreader as you can see. I believe the post has been notched to go over a little step in the concrete raft the wall is built on.
I assume as the wall isn't mine I will need to follow a similar methodology rather than popping a couple of frame fixers through the 100 x 100 timber post into the wall?
Any other suggestions on how to do this? I did consider putting the post corner to corner with the wall so that there is no overlap between wall and fence post.
