fencing lap panels to posts at angles < 90
2 Dec 2004
Hi all,
What is the best way to secure standard lap panels to posts if the required angle is less than 90 degrees?
In my garden I need to fence into and out of a corner with an (estimated)angle of between 60-80 degrees.
I don't want to force a 90 degree angle as it will effect my available driveway space considerably.
Apprieciate any comments.
Cheers, Dan.
i put a fillet down the post if its a big angle difference you have, with the fillet planed to the angle you want and then secure the fence panel to that.
If you haven't got the correct tools take it down to the timber merchant who will cut it on their bench saw or you could use a single strip of feather edge fence and build it up to the angle you want onto the post.
BUM !! I was gonna suggest that !!
