Ferolli 25c boiler
5 Oct 2011
Yorkshire
Hi can anyone help please.? Since recently trying to turn my boiler onto winter setting using the dial. The boiler will not work! The display shows the temp going up but then just goes back to zero. I have but the boiler into test mode and works fine for the 15 minute test. Any ideas?
I presume its a combi and the hot water is OK.
Has anyone turned off the rad valves or have the TRVs turned off or become jammed off.
They are not an engineers favourite but you may need to call someone to diagnose the fault if the rads are all really on and all the controls are in the correct setting.
Tony
