Hi i was wondering if anyone can help me?
I have a 77ff combi boiler which has a fault,when the boiler is switched either to ch on or hw on,it does not ignite the main boiler,i have found that i have no voltage feed from the pcb to the main gas valve,i have tested the valve by putting the thermostat wires on it just to test it and the boiler ignites ok,i got hold of a secondhand pcb which was supposed to have been tested but when fitted it there seemed to be even more problems.i still had no feed to the gas valve ,no feed at the thermostat wiring at the gas valve,also the fan is running constantly,i have now fitted the original pcb back in,is there some sort or sensor that tells the pcb to give the voltage to the gas valve,if anyone has got any ideas it would be much appreciated,jim.
