Ferroli Combi 77 FF Help Pls!
14 Nov 2005
Birmingham
Hi, I was trying to adjust the water temp on my boiler and have accidently changed the P2 switch setting (I know the sticker says NOT to alter the P2 and P4 factory settins!).
Does anyone know what the setting should be (manual or picture). It's a 'turn type' switch. Also can the boiler lead to damage if the setting has been changed. PLEASE HELP!
you shouldn't alter it, it is factory set and controls the gas pressure for hot water, should be marked where it was set before.
That reminds me, does anyone have the MI that they could email me on this model?
Subject has apparent PCB fault where it will only provide CH or DHW if the mains is switched off before the demand.
The red light is often on, is this the CH timing delay indicator?
Which board revision Tony?
Unfortunately I dont know and all I can say is that the plugs/sockets are encased in white plastic whereas I seem to have seen them before with rows of bare push on contacts which would be a pain to change?
Does that help?
Replacement would be the usual course of action but the property is due for demolition in six months so they want toe old one repaired!
