Ferroli modena 102 venturi
16 Mar 2009
Dumfriesshire
Hi, My Ferroli boiler has stopped igniting. On investigation one of the venturi on the tube from the air pressure switch had disintegrated, further investigation shows the other to be disintegrating also. iIhave searched for part number/ suppliers with no success. Any help would be appreciated.Thanks
DIY.com/Forums said:
This site does not support DIY gas and posts giving advice on gas work, or encouraging or suggesting it, may be deleted. However, posts are not routinely monitored, so no work should be done as a result of seeing anything on the site.
ANYONE PERSISTENTLY GIVING ADVICE REGARDING WORK ON THE LISTED COMPONENTS OR REPEATING IT ONCE DELETED, CAN EXPECT TO HAVE THEIR MEMBERSHIP OF THE SITE REVOKED.
Anyone seeing such a post should raise an"Alert" so it can be dealt with.
Knowledgeable members should refer to this section, avoiding any confrontational or abusive language at all times.
Read more: //www.diynot.com/diy/threads/diy-gas.8090/#ixzz3pRKdcg5e
Not the reply you want but you really shouldnt be attempting this yourself, you have already opened the combustion chamber which you shouldnt have done, its fine trying to save a few bucks but this is something that could be dangerous
To be fair they almost never work by just replacing the venturii anyway. I'd pass the responsibility onto someone like bg with a fixed price warrantied repair.
For all those taken in about how innovative Intergas is, having no diverter valve, hot water heat exchanger etc, just look at the Ferroli Modena 102. They were doing this years earlier.
A quick Google comes up with;
http://www.heatingspares247.com/ferroli-venturi-kit-short-39809790.html
As Ollski says, they are a pain. So many versions of circuit boards for a start. BG are welcome to them, at least they can buy the parts cheaper than the rest of us.
