Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Yes they're usually badged as though the maker is "FER". Popular with independent merchants. They seem to be OK in a Ferroli sort of way. Use the Ferroli tech help line which is good.
Is the problem in the fan/air switch dept?
****** ****, I've got a manual!! GC no 47-26701. I could scan you a few pages but there are 57..
air pressure switch changed by previous engineer, suspect pcbor thermistors as it goes to lock out without even trying to ignite,a manual would be useful but i think i will wait till monday and talk to technical thanks anyhow,
