ferrolli maxima presure drops off when rad temp turned up
22 Mar 2004
Hi All :cry:
Can anyone assist with this problem on my ferolli boiler.
I think I had a leak in the system and used a leak sealer to cure this. Seems to have worked ok as the pressure now holds.
During the cold spell I turned the radiator temp up on the boiler to 70 c.
The pressure fell almost overnight, so I topped it up and it dropped off again overnight. I turned the temp back down to 55 c and topped up the system again and the pressure seems to be holding ok with perhaps a slight drop over a few weeks or more.
The system pressure seems to hold ok when set to 55 - 60 C or lower. When I turn the temp up above this the system pressure falls off almost overnight.
Could this be a leak in the system and the sealer won't cope above 60 c or could there be another fault such as a PRV. No water is leaking from any visible pipes, drain valve or the boiler. I live upstairs in a conversion and my downstairs neighbour has not reported and water ingress.
Any help would be appreciated.
Gadgetman :cry:
Most likely that there is not enough space for expansion. The hotter the water gets = the more it expands. Check the prv is not discharging outside when the boiler stat is set to 70
Steve
Hi Steve
Thanks for that. I have had suggestions that the expansion vessel may need recharged or replaced. I will check this and the prv today and post a reply.
Ritchie
