I have a 90 deg isolation value with a fibre washer in one end.
Can you fit/mate the end of a tapered compression fitting (ie nut and olive removed) to this ??
Or should I be using brass hexagin nipple (that has a flat end) into the fibre washer end.
What is the difference between a Service Valve and an Isolation valve, the former contain fibre washers, the latter Olives.
Pics illustrate ...
Pics illustrate ...
