Fiesta indicator problems
  • Thread starter Thread starter Dam
  • Start date Start date
Dam
2 Nov 2005
Nottingham
I have an N-reg (mk3) fiesta, and there is a problem with the right hand side indicators. Sometimes they will work ok, but more often they will not work at all. When they are not working the click sounds at double speed, and the light on the dash doesn't flash either.
I have heard that this could be a relay problem, so could anyone please tell me where to find the relay and if it is easy to change myself?
Thanks.
Correct me if I'm wrong, but isn't the relay located on the back of the indicator switch underneath the steering column cowls?
Pull it off, plug a new one in!
Dam check your indicator bulbs are working okay. I have a W reg fiesta and I've noticed that my car does the same when a bulb blows out or if I remove a bulb.
