FIESTA "L" REG.....BLUE SMOKE ON START UP !!!!
HI ratm, GOOD man lol.
AS you correctly say there is always a risk when flushing high mileage engines, but, if its a choice between the devil and the deep blue sea, then you have to make a choice, to flush or not to flush. Over the years I used and sold Forte I never wrecked an engine, I flushed many an old escort with the dreaded CVH engine ( sludge buckets )I remember doing one for a haulage company, it had failed its mot... thick blue smoke, I warned the guy it could finish the engine,( the car had gone round the clock ) he said " well its, not worth a strip down " I flushed the bottom, gassed the top, it passed it's mot and the next one a year later ( well on emissions it passed )
If the rings are gummed in... and released with the flush there is an oil fortifier that can be added to the new oil, it puts a coating on them and still allows them to do their job.Saying that a diesel engine is harder to kill with a flush, given what they run on and the fact that the compression ratio is much higher,they do get gummed in but, not to the extent that they do on a petrol. I found they freed up without much fuss at all.
Diesel fuel conditioner, its fab, but use with caution, put the can into a FULL tank of fuel, many people don't know that diesel tanks are a playground for bacteria, this bacteria feeds of the carbons in the fuel, it has the damp dark tank and so thrives. DFC has an antibacterial property in it, if you add it to a half tank of fuel you will kill the bacteria all at once, cough cough splutter, filter blocked, fuel starvation, car packs in, then when you take the filter off there is a pile of slime in there. By adding to a FULL tank of fuel the bacteria will be killed slowly, it then mix's with the fuel and is burnt in the combustion process.
If you have thick black smoke ( unburnt fuel ) then the DFC will clean and restore the spray pattern on the injector nozzle, I did one the other day it failed at 9.7 two days later when the fuel was almost gone my cousin re-fuelled and we checked again it was down to 1.2 I think...
If you own, run or have access to a garage, check emissions, ( the full monty ) take compressions, test drive, treat and do the same again, note the figures, re- check in a few months.
Strip down..... or a few bottles..... she says to the man lol
Lynn
Hi Davy007, Let us know how you get on.
AS for the cost of the work.... I ain't got a clue lol But if it was me.... given the age of the car I would just go a good independent.
Lynn
OOPS! I forgot, nearly all the forte products are used a s a preventative measure too, they are not just for curing problems. The seal conditioner can be used in petrols, diesels, and in the diff ( except for limited slip)
Lynn
Lynn
I will have the Forte Gas Treatment tomorrow, so will do job on Saturday.
Before i read all the instructions etc etc Tilly-1 from your experience do i need to have a full tank of fuel in the car ?? and would it be an advantage to run the car for a certain amount of miles straight after and or the days after ??
Got a few independent garages close by, hoping not to use them thou ??
Cheers for now.............
Hi again, full tank of fuel... and just use it as normal, didn't you get the seal conditioner too ? Gas does the top rings, seal conditioner is for the valve stem oil seals
Lynn
Oh yes, just pour it into your engine oil, is the oil clean ? you don't want to do an oil change just after putting it in.
It could take a little while to work ( depends on the amount of driving you do) obviously it works best whilst the oil is hot and circulating, it slowly cuts through any dirt and gets to work
Lynn
Did post reply about oil but seems to have gone !!! Maybe my laptop needs some of this Forte treatment !!!!
Anyhow, oil change done end of last year so what ! 3 months old !!!
Getting the gas treatment today, you think i shud wait for the seal conditioner to arrive and do both together or best getting the gas treatment in asap followed by seal cond when it arrives ?
Appreciate your continued assistance Lynn.... :)
Cheers and here hoping........ :)
Hi again, just put in what you have, and see if it makes any difference, but you should see a difference in performance after he gas though. I put one in my Lexus last week it runs smoother and feels a bit more responsive.
Lynn
